Tomdol
Where to buy the battery for P2?
Sat Nov 11, 2017 1:23 pm
My battery runs for half an hour. In Poland I can not exchange it, there is no service. Where can I buy a new battery for P2? And how can it be exchanged, how does the phone open?
Re: Where to buy the battery for P2?
Sun Nov 12, 2017 1:45 am
Hi Tomdol,
sorry to hear that your battery is defective. Best would be to send the phone back to your dealer for warranty.
It is quite difficult to open the phone, esp because of the wires that connect the fingerprint sensor and the antennas. We do not recommend this as it is very difficult and you would loose you warranty. The cable for the fingerprint sensor breaks very easily. You would need to melt the plastic covers on top and bottom of the mobile by heat and then open the case very carefully with a very tiny screwdriver.
There is no manual on how to open the case. I read about some discussion on 4pda, which is a Russian forum: Image
Batteries you could get from AliExpress, here one example: Just search on http://www.aliexpress.com for P2 battery
Tomdol
Mon Nov 13, 2017 1:00 pm
Thank you. Is the same battery in P2 and P2 lite?
Mon Nov 13, 2017 9:22 pm
Hi Tomdol,
you are welcome. I think the batteries are the same.
But concerning my own experience with Aliexpress, I would really recommend to select a dealer with a good feedback. There are many that sell fake batteries with a low capacity. Best would be to take the battery out and compare against pictures shown on Ali. Then, just in case, you hurt any of the cables you could order those along with the battery.
I had myself two cases where the capacity was not even half as they promised. Just mentioning so you do not wonder or have to repeat the whole process.
