cakpras
Menu Tray the light is not on! After Update Via OTA BV8000Pro_blackview_20171011
Fri Nov 10, 2017 1:45 pm
HELP! After Update via OTA BV8000Pro_blackview_20171011, my Touch Screen Menu Tray the light is not on. Why?
And menu tray must be tap twice will work!
Thx before.
Re: Menu Tray the light is not on! After Update Via OTA BV8000Pro_blackview_20171011
Thu Nov 30, 2017 11:17 pm
The double tap menu tray is a common "glitch" that has been reported to the tech team.
But the problem on the light it's not normal.
Did you perform a factory reset after flashing the new firmware?
Users browsing this forum: WeraziMUH and 2 guests
