marcos.ralvesbjj
[SOLVED] pixel locked
Thu Nov 09, 2017 11:16 pm
I recently bought a bv8000 in the gearbest and with a day of use I noticed that there were green dots on the screen.
I think they are dead pixels ... How to do to fix the smartphone that came with defect ???
Re: pixel locked
Fri Dec 01, 2017 12:00 am
Two solution to have your defective device fixed:
1) Contact your seller and ask for a replacement
2) Buy a replacement display and change it by yourself. Not difficult if you have good hands.
If you need i can link to you a spare parts seller on Aliexpress.
marcos.ralvesbjj
Re: [SOLVED] pixel locked
Fri Dec 01, 2017 3:02 pm
Hello, which Aliexpress seller do you tell me to buy the original screen ???
Fri Dec 01, 2017 3:28 pm
Just chose the one that suits you more between them:
https://www.aliexpress.com/wholesale?mi ... eedQuery=n
