myname
[SOLVED] No mic audio, cant call
Wed Nov 08, 2017 6:05 pm
My blackview mic is not working anymore. I made some calls before. But now the mic is " broken ", software or hardware problem.
I'm on android 7. What I did was:
(*) Factory reset
(*) *#code# to set mic level higher
(*) audio recorder app, not working
(*) looked if something blocked the mic
(*) updated to latest firmware
I can only call with headset :o
What to do?
Re: No mic audio, cant call
Fri Dec 01, 2017 7:07 pm
It looks really like an hardware fault.
You can:
1) Contact your seller for a warranty repair
2) Buy a spare microphone and replace it by yourself, but ONLY if you have good hands for things like that.
