I am from Germany and live near the boarder to the Netherlands.
Today it's the second time I spend my vacations there and the roaming option with the BV8000 pro do not work at anytime.
Before the BV8000 pro I used a Galaxy Note 3 and a Microsoft 850XL and roaming works every time.
Firmware and apn are up to date. Yestrrday I tried the factory reset, but it does not help.
On the display the phone gets a 4G roaming connection, but I can't open any homepage. Either any app get a internet connection.
Does anyone know a solution for this problem?
Greetings and thanks for your help
