Proteus
[SOLVED] Does the SOS button do anything if I don't set a contact?
Wed Nov 08, 2017 1:36 am
Can anyone verify that the SOS button will NOT attempt to contact any sort of emergency services if I have no contact set?
Re: [SOLVED] Does the SOS button do anything if I don't set a contact?
Thu Nov 30, 2017 11:56 pm
I confirm: SOS button will NOT attempt to contact any sort of emergency services if you have not set any contact. It will only prompt you to add a contact.
