test123
[SOLVED] Cannot BACKUP
Sun Nov 05, 2017 7:12 am
I have a problem with Backup to Google Drive.
Settings>Backup & Reset:
Backup my data:On
Backup account: set
Automatic restore: On
Google Account>Backup to Google Drive - Disabled by your admin
There is no other device admin set (under Security > Device administration)
Google can sync data (contacts, calendar, notes...) but Backup cannot be made?
I've check on Google Drive, and there is no BV backup.
Anyone?
Thanx.
Re: Cannot BACKUP
Sat Dec 02, 2017 3:00 pm
your backup has been already made. You won't find it INSIDE your google drive as a file, but under "Backup Copies" in your google drive MENU.
Just log in to your google account from the website and check.
