Mike!
[SOLVED] Push notifications disappearing
Fri Nov 03, 2017 9:00 am
I have the problem that often when I wipe down the info line all push notifications disappear. I don't touch "Clear all" - they disappear by themselves. Also I noticed that they fade out horizontally while after manually pushing "Clear all" they fade out vertically.
Only way to stop that is a manual reboot. Anyone else having that problem?
Re: Push notifications disappearing
Sat Dec 02, 2017 5:38 pm
Wery weird and uncommon problem. I suggest to perform a firmware update followed by a factory reset and everything will be good. ;)
Users browsing this forum: No registered users and 22 guests
