SNap92
[SOLVED] 2 issues
Thu Nov 02, 2017 8:30 pm
I have bought a bv8000 and have some questions:
1. Why is the display very bright no matter on which the brightness setting I set it on
2. Where can I get a suitable headset for the phone since the audio jack is not a standart version
Re: 2 issues
Wed Nov 08, 2017 8:54 pm
1) Disable adaptive brightness
2) There are many shops selling fitting headphones at shopping platforms like aliexpress: https://fr.aliexpress.com/item/Original ... 8fb51450f8
jman0
Re: 2 issues
Thu Nov 09, 2017 8:19 am
Hi, admin. Instead of replacement headphones, do you know any adapters to use existing normal headphones? My ears are very sensitive and I can't use in-ear headphones for more than 5 minutes without beginning to feel a little pain.
I know I can use bluetooth, and I have already tested my bluetooth headset with my brand new BV8000 Pro, but I'd like to also be able to use my existing wired headset, which is a Sony headset with quite superior quality, which would also allow me to save more battery while listening to some music or talking hands-free.
Thanks
Aeron
Re: 2 issues
Thu Nov 09, 2017 1:09 pm
Get an adapter here. You'll be able to use any headset (with and without mic) without damaging anything.
oaimng
Re: 2 issues
Fri Nov 17, 2017 1:35 pm
For brightness, contrast issues, solving here: https://youtu.be/BbWr35f1714
Nardia
Re: 2 issues
Mon Nov 20, 2017 11:37 pm
Hi my apps aren't coming up on my home screen is says downloaded but doesn't pop up after download? Some do but some don't?
Re: 2 issues
Thu Nov 23, 2017 9:20 am
Have you tried installing another launcher, personally I use Evie.
TiveronBr
Re: 2 issues
Tue Nov 28, 2017 6:50 pm
Wonderful !!
I could solve my problem throught your post
Thanks
Re: 2 issues
Wed Nov 29, 2017 4:33 pm
Thank you so much for this help!
