conradoad
[SOLVED] The flash light is broken
Thu Nov 02, 2017 2:58 pm
I received my BV800 just yesterday, november 1st. With only 2 hour using it, the flashlight simply stopped working. I've tried every app, factory reset, but nothing. The last time it worked was when testing the app HeartRate. I thing the LED simply has burned out. What can I do?
Re: The flash light is broken
Fri Dec 01, 2017 7:21 pm
It looks like an hardware fault.
Contact your seller.
