Netsplitz
20171011 Release Notes
Thu Nov 02, 2017 2:53 am
Since Blackview don't do release notes, I thought I'll summarize the changes/bugs in a thread. Please feel free to add your comments/bugs (or you don't experience the same problem) to this thread and I'll try to keep the OP up to date, and I'll update when new versions come out.
BV8000Pro-Blackview-V0.1_20170803_20171011-0929
Android 7.0
Security Patch Level: July 5, 2017 (come on guys, it's November... this version is still vulnerable to Blueborne and KrackAttack...)
GSM Baseband version: MOLY.LR11.W1630.MD.MP.V14.P14, 2017/07/31
CDMA Baseband version: SIXTH.CBP.MD.MP5.V19_P5, 2017/07/31
Kernel Version: 4.4.15 Compiled 11 Oct 2017
Build Number: BV8000Pro-Blackview-V0.1_20170803
Comments: Touchscreen improvements (?)
Broken: Charging status stuck when unplugged with Micro USB adapter (requires reboot to clear charging status)
Broken: Bluetooth Audio drops, improvement when enable Background Task Clear
ToDo: Background Task Clear does not include all apps and widgets
Idiosyncrasies: Task switch is double tap menu, menu is long press menu. (That's just strange)
Re: 20171011 Release Notes
Thu Nov 02, 2017 4:57 pm
Thank you very much!
Netsplitz
Sun Nov 19, 2017 9:34 am
Blackview Admin,
Would be good if you could confirm if reported issues are reproduced by Blackview and if a fix is being worked on. Ideally Blackview should maintain the release notes....
Looking forward to your next software update!
Thanks!
Raf.
