Re: [TRACKED AND INVESTIGATING, ALMOST SOLVED] Phone reboots (crashes) at night, startup sound will wake up everybody
Thu Jul 05, 2018 12:59 pm
Mike! wrote:
Had no reboots for more than 2 months now after upgrading via OTA to 20180307-1950. Yesterday they suddenly came back and I had 2 reboots in only 2 days. I had the exact same situation once before.
Did you perfom a factory reset after the OTA update?
Mike!
Wed Jul 11, 2018 12:54 pm
You ask that every time. My answer is always no.
Wed Jul 11, 2018 7:12 pm
I ask it every time for a reason.....
If you update your phone and don't perform a factory reset, you can face an unexpected behaviour, as, for example, the came back of the reboot issue.
Mike!
Sat Jul 21, 2018 2:11 pm
That's what you say. But do you have any prove that a factory reset is really necessary after every update? I doubt it. It's just your standard answer. And if you read different mobile phone forums, most of them say a factory reset is absolutely NOT necessary. Also most of the people here who had a problem and did a factory reset after that still had the same problem.
It reminds me of the people who recommend you to wipe your Windows installation and do a "reset" no matter what problems you have. Which also is total bullshit. If something in my house is not working I also do not break it down and build a new one.
No offend, it's just my experience.
Sun Jul 22, 2018 2:10 pm
I respect your experience, but i can tell that a factory reset solved many problems. One of them, that i remember clearly, was about the battery drain issue still present after the update wich was released to solve it.I know what i say.
Have you ever gave a phone to a repair center? the first thing the do, even if they have to replace the LCD display, is to reset your device to the factory state. Guess why :)
Throbin_wood
Thu Aug 09, 2018 12:49 am
If the phone is rooted you can just delete the sound file located here..
/system/media
If you delete the start up and shut down animations aswell it just reverts to a stock android logo ;)
drupi
Thu Aug 09, 2018 4:18 am
my phone also started to randomly reboot itself (day, night and while charging) but only after the flashing to OREO (with factory reset)
Thu Aug 09, 2018 6:35 pm
drupi wrote:
PLEASE refer to the Oreo "service and tech" subforum.
Aksl
Wed Mar 20, 2019 12:58 pm
Ok, i have tried lately to update to the android 8.0 twice, with local update, it imitated the update process, but didn't update, i still have same version oof android 7.0 that I had. But after those attempts, it started to reboot at night, i noticed that it does that at the same time at night, and only once a night, seems like some timer in it. So, i have set in the option of automatic update, update only via wi-fi, and turned the wi-fi off for the night, and guess what, it did not crush and did not reboot...
