vetpeter
[SOLVED] Multiple Bluetooth connections fail when calling
Mon Oct 30, 2017 2:57 pm
I connect my BV to the car via Bluetooth. I do as well have a connection to a SAPHE (speed control device). As I use the phone for calling, the phone loose its connection to my SAPHE. Looks like BV don't like multitasking. Anyone with same experience or a solution?
Re: Multiple Bluetooth connections fail when calling
Sat Dec 02, 2017 5:22 pm
Yes, bluetooth usually doesn't like multitasking. It happens in every smartphone, not only in Blackview's ones!
By the way, you can increase your BT performance following the latest posts on this thread:
viewtopic.php?f=191&t=333190
Users browsing this forum: No registered users and 16 guests
