JessiM
[SOLVED] No OTA Update
Mon Oct 30, 2017 9:03 am
I own a BV8000pro for a few days now and am quite satisfied, even if small errors occur. Bluetooth I have to turn on separately when the phone was off. It does not start alone for my watch.
The notification LED lights permanently without cause. Sometimes in green, sometimes in red. Only a reboot fixes this.
But I can not update OTA. Mine version is V0.1_20170803_20170906-1035. Which would be the next and how can I get them?
Netsplitz
Re: No OTA Update
Mon Oct 30, 2017 9:47 am
I had to downgrade to 20170829 to get the 20171011 OTA.
JessiM
Re: No OTA Update
Tue Oct 31, 2017 8:44 am
How can I do that?
Netsplitz
Re: No OTA Update
Wed Nov 01, 2017 5:39 am
If you want to get the latest update, you could download firmware from here
viewtopic.php?f=192&t=213272
Download SP Flashtool from here
viewtopic.php?f=192&t=319505
Follow instructions from link above.
On the other hand, if you're not experiencing any problems, I would suggest you don't upgrade and wait for the next (local) upgrade. Flashing rom could risk turning your phone into a brick if you don't follow the instructions exactly.
In any case, good luck!
Don Harry
Re: No OTA Update
Sun Nov 19, 2017 1:42 pm
is there any chance to get the OTA 20171011 as a download for local update? I am on 20170803
Netsplitz
Re: No OTA Update
Mon Nov 20, 2017 6:24 am
I haven't tried it, but you should be able download 20170822 for local flash, and it will download 20171011 via OTA.
Good luck!
Don Harry
Re: No OTA Update
Mon Nov 20, 2017 3:41 pm
Tried it but didn´t work. Still don´t find a OTA update.
jman0
Re: No OTA Update
Tue Nov 21, 2017 7:47 am
I had the same too, when I received the phone. I had to download the whole package to install via SP Flash Tool, and that's the only way I managed to install the latest firmware from November 1st.
Don Harry
Re: No OTA Update
Tue Nov 21, 2017 6:36 pm
@ADMIN
pls offer the last OTA version as a download for local update. Would be the easiest way.
nblinov
Re: No OTA Update
Tue Nov 21, 2017 9:17 pm
2ADMIN
I too request you to get the latest firmware as local for flashtool.
