burzo
android 7
Mon Oct 30, 2017 8:25 am
Hi all, i have P2 for 2 month, i have updated to Android 7, the phone has started to, for no apparent reason to software resat it self.
restart are happening at any time, during the call or when am working on it or when on idle...
does someone have similar experience if so share?
do i try hardware restart or some custom ROM?
P.S. my apps are all from Google store
Re: android 7
Mon Oct 30, 2017 8:02 pm
Hello burzo,
if you are sure that there is no application causing this, you could try the following:
- wipe cache partition
Then try your phone again.
If the problem persists you would try to:
- wipe data/factory reset
or via the settings menu in Backup & Reset choosing Factory data reset.
This runs a factory reset. But please be aware that all you data gets lost, so please backup them in Google or locally.
david_ortiz98
Re: android 7
Wed Nov 01, 2017 11:33 pm
I managed to update in Windows 10 is easy .. and apparently they have fixed some errors the screen looks better than in Android 6 I think it spends a little battery but the performance is better than before the only thing that the fingerprint reader is a little slow and I hope they keep updating it since it is a phone that is worth having it updated and fix some things like the microphone that follows is still heard low when I try to talk to the other person
Re: android 7
Fri Nov 03, 2017 12:43 am
Hi david_ortiz98,
thanks for your feedback, very helpful. Indeed it looks more complicated than it really is, glad you were able to update.
I will report your issues of the fingerprint sensor and the microphone to our developers.
Thank you
