When phone needs to be charged as getting very low on battery. You then plug in the charger to charge the phone whilst the screen is still on and the current going into the phone is extremely low and is not charging the phone.
If you turn the phone off and plug in the charger the phone will charge.
Needs an OTA update to fix this issue.
It has already been mentioned this bug in a previous post on July 26th. So the OTA update to fix this issue seems to be taking a long time to appear.
Previous post: viewtopic.php?f=172&t=217180
When entering your finger prints the sensitivity isn't great after nougat update either. Needs improving but this battery issue is a major bug that needs a fix.
