Netsplitz
[CLOSED] Background Task Clear does not show all apps
Sun Oct 29, 2017 12:46 am
Hi admin,
The background Task Clear function does not list all apps. I have a few widgets that I would like to keep running in the background. Would be nice if you could fix that.
Also, would be good if you could update the security patch level to fix known vulnerabilities.
Thanks!
Re: [TRACKED] Background Task Clear does not show all apps
Wed Dec 06, 2017 12:10 am
Will report this to our tech team!
Re: [solved] Background Task Clear does not show all apps
Tue Dec 12, 2017 6:35 am
Not all applications can be added to the white list, such as the application of system presets will not be displayed.
GioCaLeIta
Thu Dec 14, 2017 4:56 pm
Hi, this problem is solved in rom version "BV8000Pro_blackview_20171114"
Thu Dec 14, 2017 6:09 pm
Can someone else confirm it? ;) Netsplitz?
Netsplitz
Sat Dec 16, 2017 2:23 am
Background Task Clear still does not include all apps and widgets - Try Battery Graph Widget and Transparent Clock and Weather Widget - these widgets do not have an App icon
Thu Jan 11, 2018 9:44 pm
Sorry guys, our tech team can't do more to palliate this bug at the moment.
