bigbang63
[CLOSED] MMs with picture quality bad!
Fri Oct 27, 2017 2:06 pm
when i send message (MMS) with a picture which is taken with the BV8000, the quality is very bad, I try to change the setting and increse the size (300ko ) but the result is the same.
If a copy a picture fron the net , and I send it with message (MMS) the quality is good and the photo isn't resize .
Could you confirm me is antoher person have the problem?
thanks
Aeron
Re: MMs with picture quality bad!
Mon Oct 30, 2017 10:11 am
Do you take pictures in the messaging app ? Or do you take picture with camera app then send picture with messaging app ?
bigbang63
Wed Nov 01, 2017 11:27 am
I tryed each solution the result is the same, with app camera and with the messaging app !
Aeron
Wed Nov 01, 2017 5:03 pm
So when you use the camera app, the quality of the picture is ok but when you send the picture, then the quality drops ?
Thu Nov 02, 2017 5:18 pm
Sending and receiving Pictures by MMS is limited to a size of 300K (or less if you changed that setting).
Aeron
Thu Nov 02, 2017 7:42 pm
First, he said that changing the limit made no difference.
Second, the source of the picture (camera or other) should not make any difference in quality, they should be compressed in the same way.
bigbang63
Tue Nov 07, 2017 10:45 am
hello,
I confirm with the front camera (5mp) the quality is better than with the main camera (21mp).
Wed Nov 08, 2017 8:02 pm
Thank you for your feedback. I will report this as a bug.
Re: [TRACKED] MMs with picture quality bad!
Tue Dec 12, 2017 10:58 am
Sorry, but our team can't solve this issue.
Users browsing this forum: Baidu [Spider] and 0 guests
