Netsplitz
20171011 released
Tue Oct 24, 2017 11:13 am
anyone try install this yet?
It says touchscreen fixed - i hope it's fixes the lag/reboot issue on touchscreen FT5406_МТ, VER: 0x1е
bvbw
Re: 20171011 released
Tue Oct 24, 2017 2:14 pm
Admin,
you say nothing about this update ... as usual ! :evil:
What issues are fixed ? What android version 6? 7? Google certification or not ? Are capacitive buttons fixed ? etc ... .etc ... Thanks for answer.
Ropozka
Tue Oct 24, 2017 4:10 pm
It is Android 7. Seems to have fixed the screen freezing problem, atleast for me.
Don Harry
Tue Oct 24, 2017 4:24 pm
it don´t appear on my one with And. 7
Sebastl
Wed Oct 25, 2017 12:04 pm
Releasenotes say "Optimize the problem of restarting the screen white"
HelloWorld
Wed Oct 25, 2017 1:03 pm
Also does not pop-up on my Android7 phone (non-rooted). Anybody brave enough to give it a try?
Chipolata
Wed Oct 25, 2017 2:29 pm
My BV6000 is running this release (20171011). It was quite long cause my previous one was 20160822. I had many problem installing MTK USB Drivers for Windows 10 64bits but it was ok after installing all the 5 drivers included in the Windows 10 x64 MTK USB Drivers.inf
With SP_Flash_Tool_v5.1728_Win, i Flashed 20171011 keeping my userdata (uncheck “userdata” so your data and setting may not be deleted), i got the green checkmark and i unplugged the phone.
On restart, i had many problem but the more annoying was with the continuous message « Launcher3 has stopped » « Launcher3 restarted » aso... I had to kill this app, delete all data used by this app, restart and everything is back normal.
My BV6000 is now proudly saying Android 7.0.
The last problem i have to solve is about WIFI cnx. This new version does not support WEP ... only WPA & WPA2.
Thanks to Blackview for the good work.
Regards from France.
Chipolata
Wed Oct 25, 2017 2:39 pm
Et hop ;-)
[img]
[/img]
Bluescorpie
Thu Oct 26, 2017 7:53 am
I have tried it
Its based on 0417
The last update
admin
Site Admin
Thu Oct 26, 2017 8:19 am
bvbw wrote:
Admin,
Hello, to fix the whitening problem while restart the phone.
