Karlijn
[SOLVED] Update 10 10 2017 failure
Sat Oct 21, 2017 7:35 pm
Everytime after a full download I press 'update now'. It tries to unpack bit everytime i get the message:
Installation failed
Package failed.
Please check update and download again
Ive tried factory reset 3 times but I still get this message.
Please help
Re: Update 10 10 2017 failure
Sat Dec 02, 2017 11:06 pm
Try to start the update while your phone battery level is at least at 70%.
If it doesn't work, you'll have to flash it manually.
Link to the rom forum:
viewforum.php?f=192
Remember to perform a factory reset after the update!
mbrobich1966
Re: [SOLVED] Update 10 10 2017 failure
Sat Dec 09, 2017 6:03 am
I had the same problems for months. Found out it worked flawlessly when I removed all cards from the phone. So if you have a memory card in the back, open the cover and remove it before you do the updates. Might just help !!
Sat Dec 09, 2017 10:45 am
Thanks for you help! ;)
