DeAnd02
Android 7
Thu Oct 19, 2017 5:18 am
When blackview p2 will get android 7???
Re: Android 7
Fri Oct 20, 2017 9:09 am
DeAnd02
Re: Android 7
Fri Oct 20, 2017 1:41 pm
Is a file .RAR and the phone say me that the update file must a .zip. Can i download the file in my PC and make a zip of the folder i .RAR file?
DeAnd02
Re: Android 7
Fri Oct 20, 2017 1:51 pm
Ok. I can zip the file but can i do this from PC with no programs? Can i just download the file in PC and zip the file in it and upload to my phone?
DeAnd02
Re: Android 7
Fri Oct 20, 2017 2:49 pm
And can i do it with no reset?
Re: Android 7
Fri Oct 20, 2017 4:01 pm
Hi DeAnd02,
are you trying to upgrade your phone from Android 6 to 7?
If so you need a tool called SP Flash Tool to update your mobile: https://spflashtool.com/
Then you should unpack the new ROM for your mobile in a folder, then you unpack the contents of the SP Flash Tool in the same folder and overwrite any files there.
Please follow the instructions on the SP Flash Tool webpage on howto install drivers for your mobile:
This is how to install MT65xx drivers for your windows PC. You need to install drivers in order to connect your device properly
Download MediaTek USB VCOM drivers
Driver Auto Installer v1.1236.00
The last step is a bit different, as the author of the page refers to only flashing recovery, but you would need all.
Download and unzip the package , Open SPFLASHTOOL EXE and Load the Scatter file ( Click Scatter Loading)
Switch off your device
Connect your device and Click DOWNLOAD "button" on top ( not the tab) , If it ask click "yes"
It is done and MTK flashTool will do the rest. If you have problem with flashing tool or drivers install MediaTek USB VCOM drivers from our links.
If you want to keep your data, just unselect the entry called userdata.
PLEASE never choose Format all option for doing this, as it will destroy your NVRAM.
Maybe this video helps: https://www.youtube.com/watch?v=E5m7NbzMRX4
DeAnd02
Re: Android 7
Fri Oct 20, 2017 6:10 pm
I want to use the locale updates in update. How?
DeAnd02
Re: Android 7
Sat Oct 21, 2017 11:14 am
Hey?
Re: Android 7
Mon Oct 23, 2017 8:10 pm
Hi DeAnd02, currently we only offer the method described in the previous reply.
david_ortiz98
Re: Android 7
Sat Oct 28, 2017 8:39 pm
is a bit complicated so I've seen to update to android 7 the imei disappears, because they do not launch via ota the update? please so it would be easier
