aztec165
OTA impossible to update
Wed Oct 18, 2017 1:14 pm
Dear Admin,
i can't succed to update my phone , restart never stop as the attached picture ,
do you have a solution?
thank you and best regards
i use a BV6000 since the midlle of october 2016 , unstoppable phone !
grAwp
Re: OTA impossible to update
Thu Oct 19, 2017 12:04 pm
If you want new ROM check this topic viewtopic.php?f=144&t=147109 and flash your phone via PC
frofa
Fri Oct 20, 2017 9:10 am
@aztec165: have you rooted your phone and put a custom recovery onto it (such as TWRP)? If you did, this would explain why your phone is stuck in a bootloop - that's kind of normal. So, the rule of thumb is: never do an OTA update when your phone has a custom recovery. Instead, flash the new ROM through your PC; this will also overwrite the custom recovery and all, so you'll have to root your phone again after flashing.
Thu Oct 26, 2017 1:28 pm
There are many different reasons that can make a phone impossible to receive OTA Updates. Try Flashing (directly) or Local file Update (one by one) instead.
