xty250hp
No internet in Roaming
Tue Oct 17, 2017 5:59 am
Hi everyone,
My BV 7000 Pro does not connect to mobile data when in roaming after update to Android 7.0.
Things I had done so far was
* Factory data reset
* Changed SIM cards but from the same operator (telekom.de)
* Asked the operator to send new settings to my phone for APN
* Enabled mixed (4g/3g/2g) network mode
* Manually defined the APN from my operator
* Manually gone trough all available operators for ROAMING in UK (at the moment)
Any ideas on what to try before crushing the damn thing? I travel 80% of the time so this is a KO criteria.
Thank You in advance
Re: No internet in Roaming
Tue Oct 17, 2017 2:49 pm
please
-double-check the APN setings manually.
-check if "settings>more>mobile networks>roaming" is active
check if "qick settings>operator name>mobile data" is active
if that don't help try a factory reset:
Please report if this solved your issue. Confirm if you have bv7000 or bv7000pro.
