[SOLVED] Issues in V0.1_20170803_20171011-0929 ?
Thu Oct 12, 2017 7:48 pm
Firmware V0.1_20170803_20171011-0929 is now available over OTA Update. Download file should follow in the next days.
If you have some issues with that Firmware version please post it here. This helps us to have an overview and offer a fix soon.
If possible try out first if a wipe/factory* reset will help to solve your issue.
*wipe data/factory reset in recovery (this will delete your data/settings):
- After factory reset select reboot system now.
Pasi
Re: Issues in V0.1_20170803_20171011-0929 ?
Fri Oct 13, 2017 3:21 am
Hi.
The notification led still lighting after charging cable disconnected or notifications read.
Thanks a lot.
Aksl
Fri Oct 13, 2017 9:00 am
Hello, when will the latest OTA update be available, talking about the 20171011, and what will it fix? I get a battery issue, my BV8000 pro doesn’t stay longer than 12 hours (one day) where as everyone state that their phones last for two days with one charge.
When i had BV6000, that was stolen, battery lasted 2-3 days. And that was really great thing about it! ))
JiullJuinn
Fri Oct 13, 2017 10:22 am
List button work only at twice tap.
justgenius
Fri Oct 13, 2017 11:11 am
Great phone - just arrived yesterday! :)
I have downloaded and applied this latest update, all works ok afterwards. Audio, Wi-Fi, Calls, Rear Camera, Front Camera, all seems good. Thanks! :D
Fri Oct 13, 2017 12:02 pm
20171011 should be available as Over the Air Update when you open "settings>about phone>update". I don't have a release not but I know that wrong red in photos and in app fingerprint issues are fixed now.
I am not sure if it can solve your battery issue. Short battery times can have multiple reasons, like the bigger display with more resolution. But for me the bv8000pro last two days with much time of using.
zimzia
Sat Oct 14, 2017 1:56 pm
Good work :), my pictures after the update are beautiful, very sharp and vivid colors :), and I have the impression that the phone is faster,only wifi range is very poor up to 5 meters :( but it's probably the antenna issue.
oaimng
Sat Oct 14, 2017 2:38 pm
Just updated to V0.1_20170803_20171011-0929 , clear cache + factory reset from recovery
Issues still remaining:
-bluetooth still has disconnection and robotic voice issues
-back button some times doesn't respond
-on high lights area the contrast changes in very ugly colors
(this is the same photo on bv8000, but if you direct a light to the screen(flashlight, sun light, etc, you get the ugly effect on the right)
video with constrast issues : https://www.youtube.com/watch?v=LVci6lRIUVw
An option to deactivate contrast change would be nice
Bluetooth call fix would be great
ptt, sos button deactivation or the option to set any other app/command for that button
Back button to work properly would be nice
war_horse
Sun Oct 15, 2017 7:51 am
shahardemos
Sun Oct 15, 2017 9:59 am
After the latest update, I can confirm additional fixes. For example, it seems that occasional mobile data coverage issues have stopped. the phone now manages mobile data connectivity as it should.
i just performed OTA without factory reset.
thanks
