cuchu
App drawer
Thu Oct 12, 2017 9:16 am
Hello there :-)
Just bought an A7 Pro (wanted to buy the A9 Pro first, but as I don't fancy on screen keys, decided against it) and are awaiting it's arrival.
Now I've got a question:
As I take it, it will come with your new App drawer, that places all Apps on the homescreen. I prefer the stock android way. I know there are millions of Apps to change this, but I simply love the design of your App Drawer on the Blackview A5 (my current phone). Is there a way to get this on the A7 Pro? Maybe I could download it as an App or something?
Thanks for your answer.
cuchu
Re: App drawer
Thu Oct 12, 2017 9:17 am
Just to be sure: thats what I mean ;)
war_horse
Re: App drawer
Wed Oct 18, 2017 12:50 pm
actually as you said the only solution is to install another launcher, another solution that you can use instead have an app drawer, is Settings---> App and disable the app that you don't need in order to have a cleaner homescreen.
cuchu
Re: App drawer
Fri Oct 20, 2017 1:53 pm
thanks for the reply, actually (the phone arrived by now) it has got this kind of app drawer, so there is not everything on the homesceen.
Still I feel the designe used in the A5 is beautiful, I would prefere it, but I am not unhappy with the way it is done in the A7pro, very like stock android :-)
just the settings are not placed on the left button and have to be opened allways via the phone menu or the app menu, but that's a different leaf of the book ;-)
