anass3000
[SOLVED] BV8000 PRO WON'T CHARGE
Thu Oct 05, 2017 5:57 pm
After only 2 weeks, my BV8000 PRO won't charge and also cannot be connected to any laptop.
I try it other cable but no way.
I made a factory reset also no way.
it make the same things like on this video: https://www.youtube.com/watch?v=7zcr1wxIL0g
I read in many topics on the forum and it talk about the firmware... but I did'nt find the right firmware for this problem and even if I found it I cannot use it coz of my battery is on 0%.
Can you help me please, I'm located in Morocco.
Thank you so much
Re: BV8000 PRO WON'T CHARGE
Fri Oct 13, 2017 12:44 pm
Be sure you use the original cable with long plug and it is inserted correct.
Flashing can work also with empty phone.
If nothing helps exchange the device over seller
