tmsjaeger1
[SOLVED] Checksum.ini
Tue Oct 03, 2017 4:42 pm
i tried to flash the newest rom (OTA is now working since i rooted the phone and put TWRP on it)
however i always get an error message if following the flashing tutorial as stated by the admin.
i get the error: Can not find Checksum.ini file. please use Checksumgeneratetool to generate checksum.ini.
i tried to download the checksumgeneratetool here
( http://www.dsmedia24.com/2015/11/how-to ... 0AsBM.dpbs)
, put it in the archive as stated. After 3 hours it still didnt finish.
what else can i do?
thanks
thomas
war_horse
Re: Checksum.ini
Wed Oct 04, 2017 9:05 am
try with this one, copy the entire content of the folder inside the scatter 's file folder
https://mega.nz/#!yNU2jTSL!KPd-UWIhMB9nRMQHILiZFiZQTPoarz-xshuUuQ3cyxY
Re: Checksum.ini
Thu Oct 05, 2017 1:49 pm
Please try if it work with this special version of the SPMultiPortFlashDownloadProject:
https://mega.nz/#!0T4XCAKD!IJyS0tIPEhET ... pbKU7dAex4
oaimng
Re: Checksum.ini
Thu Oct 05, 2017 6:00 pm
I googled and tryed a lot of checksum.ini generators, none worked, this one that you posted worked! Thank you very much, succes at last:
Sorry admin, I tryed your SPMultiPortFlashDownloadProject, it just won't detect my bv8000 pro, I used the one from the tutorial and worked fine:
viewtopic.php?f=192&t=319505
war_horse
Re: Checksum.ini
Fri Oct 06, 2017 8:44 am
i'm glad that it works :)
Re: Checksum.ini
Fri Oct 06, 2017 12:08 pm
Thanks for the feedback. I will correct the flashing tutorial again.
war_horse
Re: Checksum.ini
Sun Oct 08, 2017 8:35 am
Admin maybe you can add the checksum.ini generator that i linked to make the tutorial work like a charm
Re: Checksum.ini
Sun Oct 08, 2017 1:01 pm
I already did in the latest version of the tutorial.
Users browsing this forum: No registered users and 22 guests
