shahardemos
[OBTAINED] Request: Option to deactivate the PTT/SOS button
Mon Oct 02, 2017 2:49 pm
In most days, I do not need the PTT/SOS button functionality (standard working days).
However, accidentally pressing it activates the functionality I don't need.
Is there an option to deactivate it through some settings?
And keep the option of reactivating it when needed?
MB242
Re: Request: Option to deactivate the PTT/SOS button
Mon Oct 02, 2017 4:41 pm
As this option is already implented in alterenative ROMs it shoud not take ages to do the same in the stock ROM.
Wahut
Mon Oct 02, 2017 7:33 pm
Deactivate or change it to something else.
I'd like the option to be able to control the flash with it.
mbrobich1966
Mon Oct 09, 2017 12:16 am
I just removed the 4 screws that hold the little aluminum cover, removed the PTT button and put some strips of black electrical tape over the inner button. Put the cover back on and 4 screws. NOW the PTT never gets hit by accident !!!!!!!!!!!!!!!!!!!!!!!
Fri Oct 13, 2017 12:31 pm
thanks for your feedback!
nonobike
Mon Oct 16, 2017 7:46 pm
hello in developer options can we have the ability to disable this key
Johnnygeep
Mon Nov 13, 2017 4:54 pm
I also would like to have the PTT button programmable. I don't need the PTT function. And, I hate the alarm function!
Otherwise, I love my new bv8000!
Thank you,
John in the USA
Re: [TRACKED] Request: Option to deactivate the PTT/SOS button
Sat Dec 02, 2017 10:24 pm
Will forward this request to the tech team. It shouldn't be too hard to be implemented! ;)
kobalis
Re: [FEATURE REQUEST] Request: Option to deactivate the PTT/SOS button
Fri Dec 08, 2017 3:58 pm
Hello
I also want to deactivate but would prefer TO CUSTOMIZE it.
Thx !
BV8000pro (since 2017.12.07th) V0.1_20170803 (FR)
first smartphone after a long GOOGLE NEXUS Odissey :geek:
(Nexus S, Nexus 4, Nexus 5, Nexus 5X)
Tue Dec 12, 2017 7:30 am
Soon will add an on-off button to solve the problem, please keep tuned.
