David.
No sensors
Thu Sep 28, 2017 9:09 am
It seems all the sensor on my BV6000 are dead, except proximity sensor and light sensor.
It happened 2 weeks ago, not suddenly for example the gyroscope began to loose the X-axis and the rotation sensor had an erratic comportment and since 2 days no sensors seems to be alive (except proximity sensor and light sensor)
I tried the *#9646633# to calibrate some sensors, but it fails
Yesterday I flashed the 20170719 rom and reset all the phone but it did not help.
Anyone have this issue ?
Suggestions (or fixes) are (very) welcome.
Regards
David
Re: No sensors
Tue Oct 17, 2017 1:26 pm
I will reply as soon I know a solution.
