cientistagyn
[CLOSED] SugGestion - Resolution Options
Wed Sep 27, 2017 6:18 pm
I want to send this sugestion to a next update.
As in galaxy S7 (and other Smartphones) in Android Nougat, Samsung allows you to manually set the display resolution (QHD, FHD and HD), aiming to boost battery life and a better performance running apps and games.
I sugest yoy to offer this option in BV8000 pro to switch between FHD (1920x1080) to HD Ready (1280x720). In can boost a lot gaming performance and even battery life
What do you think about this?
Wahut
Re: Sugestion - Resolution Options
Tue Oct 10, 2017 9:05 am
I would also like this feature. Using my BV8000 Pro to play Albion Online, the game runs surprisingly well but it would be good to be able to get a little better performance :)
Tue Oct 10, 2017 2:09 pm
Thank you. I will forward your suggestion
Aeron
Re: [FEATURE REQUEST] SugGestion - Resolution Options
Wed Jan 10, 2018 8:15 am
Thanks for changing it :)
Wed Jan 10, 2018 12:14 pm
Can you confirm that it has been implemented? ;)
Aeron
Thu Jan 11, 2018 9:45 am
Oops I posted in the wrong thread :oops:
Thu Jan 11, 2018 9:19 pm
Sorry guys, our tech team can't implement this feature at the moment.
