cientistagyn
Bv8000 pro CPUZ SoC test.
Wed Sep 27, 2017 4:11 pm
I tested my BV8000 pro in CPUZ app and it shows my SoC is Mediatek MT6757 clocked at 2.39 Ghz, with is Helio P20 and not Helio P25 (Mt6757T) at 2.6 Ghz, as the Blackview site claims ...
... so, are there 2 versions of BV8000 pro, one with Helio p20 and a new one with Helio p25 ? Because my Bv8000 specs, acording CPUZ are MT6757 clocked 3.9 Ghz as you can see in the screenshot.
MB242
Re: Bv8000 pro CPUZ SoC test.
Wed Sep 27, 2017 6:19 pm
cientistagyn
Wed Sep 27, 2017 6:40 pm
Tried CPU X and CPU identifier apps and the result is Helio p20 MT6757CH ...
Are there two models ?
cientistagyn
Wed Sep 27, 2017 6:43 pm
However, the Clock speed, and the CPU name doesn't match Helio P20... Neither P25...
P20 is clocked at 2,3ghz, not 2,39.
And its codename is just MT6757, not MT6757CH..
cientistagyn
Wed Sep 27, 2017 7:31 pm
Tried lots of diferent apps and all them says my device is MT6757CH Helio P20 and not P25 (MT6757T or MT6757CD)
MB242
Thu Sep 28, 2017 12:08 pm
Can you please check phone with Antutu Benchmark to compare with result 63789?
Tue Oct 10, 2017 2:01 pm
The is only one kind of cpu used for this device, some apps don't recognise it correct.
