SixMan
ERROR? notification doesn't illuminate screen
Wed Sep 27, 2017 12:28 pm
If the device has off screen, the notification does not illuminate :-(
Holefighter
Re: ERROR? notification doesn't illuminate screen
Wed Sep 27, 2017 2:39 pm
Whatsapp? Or SMS? or what
grAwp
Fri Sep 29, 2017 6:00 am
Be specific, reinstall app or update ROM.
Ledlock
Fri Sep 29, 2017 12:13 pm
I have the same problem with the bv8000 pro
Fri Sep 29, 2017 2:28 pm
@Ledlock Then post your problem in the bv8000 pro forum, not here.
Had you checked the notification settings and had you tried to put the specific app to the whitelist of background task clear?
SixMan
Tue Oct 03, 2017 11:20 am
No notification illuminate screen!
Build number: BV7000_PRO_Blackview_20170706
Wed Oct 04, 2017 1:51 pm
SixMan
Thu Oct 05, 2017 1:59 pm
Sorry, but how to put the specific app to the whitelist ?
Tue Oct 10, 2017 7:45 pm
Marco-66 wrote:
I know that a notification should only turn on the led not screen ...
Thank you! You are right. I forgot this with all the different phone models and versions ;)
