albertosola
Problems with the speaker in less than a month
Sun Sep 24, 2017 12:39 pm
Hi, I bought a pro 8000 a month ago and I have problems with the loudspeaker, I hear an annoying high pitched noise, it distorts the audio as if the speaker had discon - tinued, it started to fail a few days ago, I need to know how to get a speaker spare.
Re: Problems with the speaker in less than a month
Fri Oct 13, 2017 12:56 pm
-you could try to clean the speker with a magnet, air or water
-you can ask your seller for help
-you can search for spare parts on aliexpress
prascho
Fri Oct 13, 2017 3:21 pm
I have the same problem - it seems some units come with defective speakers from the manufacturer. The merchant I bought them from confirmed this but then stopped responding my messages, so I got a complete refund from AliExpress. I purchased replacements here:
https://www.aliexpress.com/item/2pcs-lo ... 40228d8052
They come today for about 10 days from China to Bulgaria. I am waiting now for the service centre to replace them - it will be ready next week I hope.
prascho
Mon Oct 16, 2017 2:27 pm
I replaced my phone speakers with the new ones I bought from AliExpress - they were ok for exactly 1 hour and then both started to sizzle terribly!
Again - the phone cannot be used for making calls. The guys from the service center where the speakers were replaced suggested that this is most possibly a software problem with the polyphony.
I am using the latest ROM update via OTA - 20171011.
Admin - any suggestions?
prascho
Mon Oct 16, 2017 2:41 pm
I found a video of the problem - it is made by another user but I have exactly the same problem both with Loudspeaker and Earspeaker
https://www.youtube.com/watch?v=ZUi-Dysx0Vg
