kocura
Wallpaper
Fri Sep 22, 2017 12:26 am
wallpaper closes with error and restarting
Is someone having the same problem?
Re: Wallpaper
Tue Sep 26, 2017 7:19 pm
- try to use a wallpaper with lower resolution or
- try to use an other launcher from play store or
- try to update to the latest Firmware and perform a factory reset* in recovery after that.
* wipe data/factory reset in recovery (this will delete your data/settings):
