NFC capabilities seems to be limited on my BV6000.Tried to write on a NFC tag a plain text (10 lines, nothing fancy) and result is an empty tag.
Tried to write a few lines and it worked.
After some tests, it comes out that NFC write capability is limited to roughly 200 bytes.
Any of you experienced same issue?
Thks
Andrea
