naclya
Battery?
Wed Sep 20, 2017 8:13 am
Hello, I recently purchased a blackview bv6000. After working normally for weeks, the cellphone started off suddenly. I put on charge, the cell phone started to warm up and hung up. I couldn't turn on the phone again.
I've also contacted Blackview and you recommended that i purchase another battery. I've followed your videos on YouTube on how to replace a battery, and after turning on, the phone was functioning normally. Shortly after beginning to charge, instead of charging, the battery died off and now the phone will not turn on. I need some indication as to what my next steps should be.
Thanks
Re: Battery?
Tue Sep 26, 2017 6:54 pm
- is the cable working correct?
- Is it possible to charge the phone if it is turned off?
- Is it possible to charge after flashing the latest firmware and making a factory reset*?
- is the phone starting with the old battery?
- Is it possible to charge again after deeply discharge the battery (let the phone go off from empty battery, try to start again, maybe wait some days)
*wipe data/factory reset in recovery (this will delete your data/settings):
