Master-Peter
WIFI reception weak
Mon Sep 18, 2017 11:56 am
I received my BV8000 Pro some days ago. After the OTA Update I installed some Apps (Waze, Messenger, Gleeo Time Tracker) - works fine and snappy. No complains so far. :D
But the WIFI seems weak. I have compared to 2pcs BV7000 pro and a Jiayu S3 all of them show a quite good signal 50m from the source (Fritz Box) and have no connection problems. The BV8000 pro shows a much weaker signal beyond 20 meters, but does not connect. Even when I go back in its range it does not reconnect right away.
This might need improvement.
Thanks
Peter
