michal13
forgotten pin
Sat Sep 16, 2017 4:07 pm
please for advice, I forgot the pin. what can I do to keep me out of date? is it possible to unlock?
Re: forgotten pin
Fri Sep 22, 2017 9:52 am
You could try a factory reset.
