karera
Default app
Sat Sep 16, 2017 8:28 am
I can't set the default app to adobe acrobat even i chose "always". it asks me everytime what application to use to open the pdf file even i chose adobe acrobat as default.
Noé brito
Re: Default app
Sat Sep 16, 2017 2:27 pm
Obrigado. Consegui resolver a situação do meu Blackview
Re: Default app
Thu Sep 21, 2017 1:53 pm
In "settings> apps > acrobat" you can try to reset that setting and make it again. You can also restore all default open settings at settings> apps > top-right-menu .if that don't help try a factory reset*.
Please report if that helped you.
