  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
Aeron
Jack Adapter!
Fri Sep 15, 2017 9:30 am
Hello everybody !
I'm no longer making adapters for the BV8000 Pro.
You can find some on the following links :
Aliexpress
Amazon
alvarobb
Re: Jack Adapter solution FOUND !
Fri Sep 15, 2017 10:31 am
please give us the link
Targun
Fri Sep 15, 2017 10:32 am
Adapter is NEVER a convenient solution.
And why would you even post a topic if you don't have it ready yet?
shahardemos
Fri Sep 15, 2017 11:43 am
for sure we will like it. i also tried to find something, 17mm male to standard 15mm female, both sides TRRS, but i could not find one.
share the link to where your found it and the results of your test and we will be happy.
Aeron
Mon Sep 18, 2017 8:42 am
I'm not talking about an adaptor I found. I just found the proper long TRRS jack.
I'll build a adapter cord for myself and was wondering if some people here would be interested in a homemade solution.
I'm not sure everybody likes an extension style adapter made by hand, which for sure wouldn't look like a factory made one.
shahardemos
Mon Sep 18, 2017 10:43 am
Thanks, I'm asking few ebay and amazon resellers to check if they can order 18 mm long male to standard female TRRS adapters... Maybe they'll manufacture several hundred... and we'll buy...
Aeron
Mon Sep 18, 2017 2:50 pm
Please let us know, it would save a LOT of time ! (none of the adapter seller I've contacted were willing to make some)
hcf1511
Mon Sep 18, 2017 6:14 pm
I need an adapter so badly, so would be very interested in yours!
w1ldh0ney
Mon Sep 18, 2017 6:26 pm
BV8000 Pro
I tried by cutting the plastic edge of a USB to USB-C cable, and a 3.5mm adapter. They seem to fit correctly, but unfortunately both failed.
They work properly with other devices.
I sent a support request to Blackview. Please encourage the solution by submitting solution requests. I think the necessary adapters must be provided by Blackview for free.
Robjf
Fri Sep 22, 2017 10:47 pm
A quick and dirty solution that works well is simply to take a sharp knife to a suitable existing jack. I have done this several times - works great with cut iPhone headphones.
Does anyone know if the USB-C supports HMDI output on the bv8000 pro? I am tempted to trim a usb-c to hmdi to try it out so I can connect to screen using something other than chromecast
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
