gialu
screen blocked
Fri Sep 15, 2017 9:00 am
I buy a Blackview BV6000 phone; I forgot the screen block sequence for have access to phone.
I try several time.
What can I do?
Thank you very much
Gian Luca
Re: screen blocked
Fri Sep 15, 2017 5:30 pm
