will@nolsd.com
Bv5000 second sim NOT Working when in hotspot
Sun Jun 12, 2016 4:08 pm
When using hotspot, Data not working for connected devices when using second data sim.
But works on the Bv5000.
Is this a known problem? And is there going to be a fix?
Thanks
masavini
Re: Bv5000 second sim NOT Working when in hotspot
Mon Aug 07, 2017 8:30 am
same problem here using bv5000 with android 5.1, except hotspot is not working even using the first sim slot...
- data connection is working on the phone
- usb and bluetooth tethering are working for both the sim slots and any client
- clients can connect to the wifi network but they can't access internet
does anybody know if update to android 6.0 fixes this?
