BJSr
[SOLVED] Battery charging voltage change.
Thu Sep 14, 2017 12:28 pm
On my BV8000 Pro, with rom V. 0.1_20170803_201708. the charger voltage (BV60) went down from 12v to 9v.
Why was this changed? Would like to have 12v back.
Regards
Re: Battery charging voltage change.
Tue Sep 19, 2017 3:18 pm
Thanks for your feedback. I will report this.
JiullJuinn
Fri Sep 22, 2017 2:37 am
12v not good. Don't back
Fri Sep 22, 2017 1:47 pm
What's the problem with 12V?
JiullJuinn
Fri Sep 22, 2017 2:07 pm
Becouse it is show 12.6v Battery will die)
