shellshokt
Help with BV600
Fri Jun 10, 2016 8:08 pm
Just received my BV600 and apart from a quick start guide, which seems generic, there are no instructions for using the phone. I cannot get the phone to recognise my sim and it does not seem to fit properly in the 'holder'. Do you have any instructions or pictures of how the sim should be inserted?
Many Thanks
Steve
Re: Help with BV600
Sun Jun 12, 2016 8:13 am
For using the phone , we have released a function-show video . you can find on Blackview Youtube channel.
Then for how to insert the sim card, i will inform my colleague to make a short video.
Best regards,
Admin
Re: Help with BV600
Sun Jun 12, 2016 8:31 am
shellshokt wrote:
Many Thanks
Steve
here is a picture for you , hoping you find the right place to put sim cards.
BV6000 Sim card_副本.jpg (91.49 KiB) Viewed 3111 times
Best regards,
Admin
