bv7000owner
screen way too sensitive
Sat Sep 09, 2017 7:32 pm
I have the problem that on my newly recieved BV7000 the screen is abnormally sensitive, it registers touches with the fingers being several millimeters from touching the glass. As you might imagine this makes it more or less unusable with misclicks all the time.
anyone else experiencing this?
I tried posting this message several days ago here, but it did not show up.
I also have a BV8000 pro which works fine
Re: screen way too sensitive
Tue Sep 12, 2017 9:39 am
update to the latest Firmware and perform a factory reset in recovery after that.
Tue Sep 12, 2017 3:52 pm
You can also try this:
Under settings > Language > keyboard > pointer speed set the slider to the minimum
bv7000owner
Fri Sep 15, 2017 6:18 am
I have tried this, it doesnt change anything.
Wed Sep 20, 2017 5:34 pm
Thanks for the feedback. I will report this. Please keep your phone up to date to receive the latest bugfixes.
