mudmax79
BV5000 turns off by itself
Fri Jan 15, 2016 5:14 am
I bought a BV5000 one month ago.
My phone turns off by itself all times when bettery power is under 60%.
Is it a battery problem or is it a phone problem?
Thank you
ROM version 1.2_20151023
Re: BV5000 turns off by itself
Fri Jan 15, 2016 9:14 am
Hi ,
If you do not play games ,then how long you can use it before the battery show 60 percent ?
Best regards,
Admin
mudmax79
Fri Jan 15, 2016 10:58 am
Maybe about 3-4 days. I don't know exactly.
dave136
Fri Jan 15, 2016 6:05 pm
Try instal last FW from PC.
Sat Jan 16, 2016 6:41 am
hi , you mean for full time charge , it can last for 3 to 4 days ?
Re: Re BV5000 turns off by itself
Sat Jan 16, 2016 6:44 am
Margiebar wrote:
I hear only one beep just before it turns off.
removed battery tried turning it on with components off, on..and nothing. it goes down to the motherboard and CPU.
You also have the same problem .
Best regards,
Admin
troxter
Sun Jan 17, 2016 9:03 pm
Having the same issue. Phone turns of by itself (auto shutdown in is has not been set)
mudmax79
Mon Jan 18, 2016 5:06 am
Yes, if I charge it Monday, the battery will be at 60% Thursday or Friday ( no game )
Tue Jan 19, 2016 8:08 am
Full charge can last for for 3 to 4 days , it is normal, so the problem may be something wrong with the
battery condition showing .
Best regards,
Admin
mudmax79
Thu Jan 21, 2016 5:17 am
I sent the phone to the seller.
I don't know if I will buy another BV5000 because I see that there is a lot of problem.
It's a pity because I like this phone.
