gt40emn
bluetooth
Sat Sep 09, 2017 9:49 am
Can't use bluetooth on my BV7000.
My phone won't connect with any bluetooth device.
Have this problem from the start. (June 2017)
Any suggetions?
Re: bluetooth
Tue Sep 12, 2017 5:13 pm
- update to the latest Firmware and perform a factory reset* in recovery after that.
- also try an other bluetooth device.
* wipe data/factory reset in recovery (this will delete your data/settings):
