Cccake
Conception telephone app
Tue Sep 05, 2017 11:24 am
i have a question, but first " Thank you very much blackview for very good maching of the last updates! All works fine now"
but now my questions:
1. is it possible to change the original telephone app a bit? when importing and for new contacts i can´t find any birthday informations. great would be also more date possibilities like birthday family etc.
2. when i ring up somebody i have always the problem not to get in touch with the small icons loudspeaking, numbers etc. must hold my phone in a "special" angle not to touch. think this could also be a problem for connection problems because of unintended hang up the call. perhaps the icons can get a little lower on the screen then or other...
in caes of the original calendar app: like the app, but now im/exporting functions are integrated. for me it would be nice to have this option two, because of not exchanging with other device or with clouds. i know this function is only "pro" in other apps we could install instead.
thanks for your interest
Re: Conception telephone app
Thu Sep 07, 2017 8:41 pm
You could try other apps like "google calendar" from play store.
Cccake
Tue Sep 12, 2017 2:44 pm
thanks for request admin.
something i registered new with the telephone app is that if i´m in a call sometimes the microphone button is activated (how can it be without pressing button..), so on the other side no one can´t hear me anymore. After pressing the loudspeaking button we can hear each other again and after second press onto loudspeaking the other side can hear me again. if i press the microphone button its not changing green like loudspeaking button so i can´t see if its activated or not.
Tue Sep 19, 2017 2:05 pm
Maybe try if disable the "OK google" feature. Sometimes that google app is using the microphone so that it is not usable during calls.
