PieroM
Screen problems
Tue Sep 05, 2017 7:19 am
Hi!
I just bought my new BV 8000 PRO and everything was perfect! Until last night...
Last night the phone was out of charge so I decided to charge it with a power bank. After one our I picked up the phone but, I couldn't turn on the screen: it was turned off with the red led on!
This Morning the screen is off but the phone still works (I tried with the volume buttons and I restarted it some times).
What should I do?
Thank you!!
Re: Screen problems
Tue Sep 05, 2017 11:07 am
Hello. Firstly, try to flash latest stock firmware. If issue not will be fixed, you need to contact with your seller about warranty repair. Download link of firmware. viewtopic.php?f=192&t=213272
