melik
Notification LED always on
Mon Sep 04, 2017 11:23 am
since this friday I habe new BV8000 Pro. I did several upgrades. Now my software is "20170829".
Problem is that the LED is always on. After reboot is for a while off, then without reason LED is on - red or green. And it never goes off (no notification pending), till next reboot.
Admin: is this already known issue ? Is there workaround for this ? Will be maybe fixed in next patch?
Regards from Cracow, Poland
melik
P.S. please remove this shitty sound from boot screen ;)
Re: Notification LED always on
Tue Sep 05, 2017 11:15 am
Hello! Copy all your personal data and try to make factory reset. If don't help, try to flash stock VIA PC: Link on firmware: viewtopic.php?f=192&t=213272
